Disassembling Corgi Fire Truck
Postby 19ENGINE on Fri May 23, 2014 11:39 am
How do you disassemble a Corgi heroes under fire fire truck to kitbash it without wrecking it? Can someone point me in the right direction. thanks
19ENGINE
Re: Disassembling Corgi Fire Truck
Postby chariots of fire on Fri May 23, 2014 9:30 pm
If they are the ones I'm thinking of you should be able to drill out the rivets on the bottom and take them apart that way.
Postby 19ENGINE on Wed May 28, 2014 1:13 pm
Thanks, I'll give it a try. I removed the screws but that didn't do anything.
19ENGINE
Postby chariots of fire on Wed May 28, 2014 5:46 pm
Which one do you have? I have several. If the same I could look it over.
Postby EdselDan on Thu Aug 28, 2014 2:17 pm
I have not done this on a Modern "Heros" series rig, but have disassembled 2 of the OLD ALF TDA.
Yes, all you need to do on those is drill out the rivet holding the chassis to the body.
I have shown pics before, but can again here if wanted.
I do have a second Cherry Hill NJ Mack CF Aerialscope I could part out/rebuild though.
Got it Cheap at Tuesday Morning a few years ago (Only $7.oo +tax due to broken parts/damage)
I did get Some parts from Corgi, but not all needed.
I later got a complete Mint one.
