What size hose?
What size hose?
Postby Lyonsperf on Thu Dec 04, 2014 10:42 am
Can anyone tell me what size the hose is on the front of this truck?
What would it be in 1/25 scale and what size tubing should I use to make the couplers?
Thanks!
Lyonsperf
Re: What size hose?
Postby chariots of fire on Thu Dec 04, 2014 1:37 pm
I see two possibilities. The booster hose is probably 1" ID which would make the OD probably 1-1/4". I use small electrical wire with red insulation for that. Probably 1/16" dia would work best. For the cross lays they are probably 1-1/2" cotton jacket hose. I'd use 1/8" flat sewing elastic for those and you can find it in any sewing shop or any store that carries sewing materials etc.
Re: What size hose?
Postby GLMFAA1 on Fri Dec 05, 2014 12:20 am
Looks like 4 inch soft suction to me. in scale 4 mm in diameter. Use the Hard suction ends from the AMT kit, the end that is the female would be in the tray and the male end on the pipe
Re: What size hose?
Postby Lyonsperf on Fri Dec 05, 2014 9:12 am
Thanks guys!
Lyonsperf
Re: What size hose?
Postby Lyonsperf on Sat Dec 06, 2014 10:43 am
FYI, i found that the single Lego studs that come with most of the ir building kits work well for soft suction couplers.
I sand the male end off that has the lego name on it and then drill out the hole!
A quick coat of silver paint and some super glue and you have a coupler.
They have many other parts that lend themselves to our building, but my kids don't appreciate me raiding their toys!
Lyonsperf
