Ford C600 Kit Question
Postby Daveski25 on Sat Dec 06, 2014 2:53 pm
Ok, so I'm building the AMT Ford C 600 stake truck ( Lime Green ) :D and I have ran into the same problem as I have in the past with these kits. The Air Cleaner and mounts interfere with the cab sitting level :twisted: I have tried moving it back slightly but it still effects the cab sitting properly. Is this an error in the kit?? Or am I doing something wrong?
Dave
Changing the world one Model Fire Truck at a Time!
Daveski25
Scale Firehouse Addict
Re: Ford C600 Kit Question
Postby Aaronw on Mon Dec 08, 2014 2:08 am
It has been a while since I've worked on this kit, but as I recall it is just a matter of getting things lined up right although not necessarily where the kit suggests things should be.
Postby chariots of fire on Mon Dec 08, 2014 2:31 pm
Can you lower the air cleaner a bit somewhere that it does not show?
