Making Tandem axle ALF trucks
Postby explorer2770 on Sun Nov 06, 2016 3:17 pm
I'm curious to know what other modelers have used to make convert their ALF ladder and aero chief single axle rigs to tandem axle rigs. With the re-re-re-release of the AMT Aero Chief, I'm tempted to make a tandem axle quint using parts from the pumper kit. I'm just not sure which kit I need to source the tandem axle from, I'm leaning towards the White/Freightliner kits but not quite sure which kit to use.
Thanks for the advice!
Re: Making Tandem axle ALF trucks
Postby chariots of fire on Sun Nov 06, 2016 6:20 pm
Unless you are trying to be super correct as to what ALF may have used, it doesn't make a lot of difference which style you use so long as it all works. There are several kits out there that have tandem axle setups that you can use. The AMT Ford Dump Truck, KW, Pete kits all have tandem axles that can be adapted. The Mack kits have a different suspension that makes the distance between axles somewhat longer so check that out. When all is said and done you won't see much from the outside anyway so which one you pick is up to you. I'd probably settle for the walking beam suspension that has a central pivot point that allows both axles to travel up and down. The biggest concern is to make sure that the frame still sits nice and level from front to rear when axles and wheels are all glued in. Hope this helps.
As an aside when you get your tandem axles in place and are ready to do the body work make sure that the wheel well openings are smooth and follow the curvature of the tires. Try finding pix on line of tandem axle rear mounts and look at how the panels are done. They are not all the same depending on the manufacturer of the apparatus.
Hey GREG SMITH!! Chime in here will ya? You built one that has the look.
Postby GLMFAA1 on Sun Nov 06, 2016 10:28 pm
OK I'll chime in and suggest that the best tandem set is from the Ford LNT kits. The chassis has to be modified in the back as the frame is reduced and needs to be thickened, and the springs need to be placed on the sides of the frame and not like the kit placement. . I will do a 'how to' if you guys are interested
Postby explorer2770 on Sun Nov 06, 2016 11:13 pm
I would be greatly interested in a how-to. I'm kicking around three tandem axle builds, a quint Aero Chief, a heavy foam tanker (pseudo-Airport chief), and a heavy rescue all on the 1000 series chassis.
Postby EdselDan on Tue Nov 08, 2016 2:37 pm
I have done a coupe Tandem conversions in 1/32 scale
with Monogram's MACK CF but the idea and conversion is the same
The Aerialscope project used 2 Pumper chassis and 2 sets of rear axles
I did remove the mount from one spring and adapt the other to have
a single mount for between both springs.
The Heavy Rescue used the Walking Beam set up from the R Semi Cab cab
Less work, BUT MAKE sure the 2 frames are STRAIGHT and SQUARE!!!
For the Most part here the tandems are 4 feet center to center.
I did convert an ALF to Tandem, But that is my Scratchbuilt Pioneer Snorkle in 1/32
I just used a scrapped Monogram kit semi for the suspension
I do want to do a couple 1/25 ALF tandems, But......
For a Ladder Chief want to convert it to a 4 segment 100 foot unit
For a Snorkle, Again, I would prefer to stretch the booms to the 95 foot unit
A Rescue or Airport Foam unit would be the easier build
so may look at those Ideas
I do have a few Parts lots of AMT ALF parts.
I did check the regional Hobby Lobby, but $60.oo (40.oo with 40% coupon is a Bit High
for me for the Aero Chief kit right now.
