Lindberg Crown Victoria Lightbars
Postby EdisonMarius on Sat Jan 07, 2012 3:36 pm
How do I remove the paint from the Lindberg pre-painted lightbars
EdisonMarius
Re: Lindberg Crown Victoria Lightbars
Postby zoomzoomzee on Sat Jan 07, 2012 11:15 pm
rubbing alcohol or windex should do the trick
zoomzoomzee
Elf Wrangler
Postby EdselDan on Sun Jan 08, 2012 10:37 pm
91% Rubbing Alcohol worked Very Quick for me.
4 days in Wesley's did nothing. Under 4 hours in the Alcohol had the crystal clear again!!
Postby brian3182 on Mon Jan 09, 2012 12:21 am
how about the welly ford crown vic 1/18th scale front corner parking light lense??? the whole thing looks amberish, would this work also? I would like it to look like the real 1:1
brian3182
Postby EdselDan on Mon Jan 09, 2012 6:15 pm
I don't know what Well uses to 'paint/tint' the lenses on their 1/18's so I don't know
Can't hurt to try though
And with Alcohol, you don't need to worry about wearing rubber/latex gloves
Postby brian3182 on Mon Jan 09, 2012 9:22 pm
ok i'll give it a shot right now
brian3182
Postby EdisonMarius on Mon Jan 16, 2012 9:52 pm
The alcohol did work
EdisonMarius
Postby Gator52 on Sun Dec 27, 2015 9:45 pm
I successfully used the 91% isopropyl and was pleased with the results; in less than an hour the lens was as clear as ever, no hint of red at all...worked much better than I expected.
Thanks for the tip.
Jonah
Gator52
