amt aerochief 1000
amt aerochief 1000
Postby steveng on Sun Nov 22, 2015 6:50 pm
Hi everyone I am new here and have a question On the aero chief 1000 I am currently building the diamond plate has a few injector sinkholes. What is the best way to fill in without loosing little detail ?
steveng
Re: amt aerochief 1000
Postby chariots of fire on Fri Nov 27, 2015 8:58 pm
Try filling the sink holes with a little superglue and let it sit until cured. Body putty won't work as you will have to sand a lot of it away and the detail will go with it. Can you substitute some treadplate from Don Mills? He makes a good piece that you can cut into any size you would need.
Postby Jeff_C on Fri Jan 01, 2016 11:48 pm
Charlie,
The Don Mills treadplate is scaled more for 1/32 scale.
Plastruct has some that is much easier IMO to work with. It's the tan colored one, and IIRC it says its HO scale.
There is also treadplate by JTT Architectural Model Parts #97449.
Jeff_C
Postby EdselDan on Sat Jan 02, 2016 1:00 am
Unless they have changed the size of their "HO" scale Tread-Plate
Plastruct's was closer to 1/32
It was what I used on ALL my 1/32 bashes & Scratxhbuilds
It matches(Matched) That on Monogram/Revell 1/32 Snaptite
truck kits. Not Just the MACK CF Pumper, but all others too!!!
Postby chariots of fire on Sat Jan 02, 2016 11:23 am
Don's treadplate is very close to what is in the ALF kit. The difference between 1/32 and 1/25 treadplate is not that noticeable once it is in place.
