NYPD circa 1962
Even The Cop Cars Are Welcome, Just Watch The Doughnut Crumbs
NYPD circa 1962
Postby GLMFAA1 on Thu Oct 29, 2015 11:36 pm
I have had a Revell Dodge for years, bought it to get the louvers set on the chrome tree (Mack cab need)
So I took it and mixed the JoHan parts and decals to make an NYPD car. I kept the 440 bling on it as I was not in the mood to dechrome all the lines especially when one side is engraved deeper than the other side. Ii always wanted to do a NYPD car and it is fictitious as the sirens didn't come into use until 63. Tamyia green, black and Walmart white can for the paint.
Re: NYPD circa 1962
Postby Robbo on Fri Oct 30, 2015 1:48 am
I like it, that's one very nice looking law enforcement vehicle. Fictitious or not, it's how one wants the finished model to look like and putting to good use of parts available.
Cheers from Robbo.
Re: NYPD circa 1962
Postby GLMFAA1 on Fri Oct 30, 2015 12:54 pm
I'm seeing the photos as too large, so I am reposting using photobucket
Re: NYPD circa 1962
Postby maxwell48098 on Sun Nov 01, 2015 12:13 pm
That is so cool.
A.J.
maxwell48098
Re: NYPD circa 1962
Postby Aaronw on Mon Nov 02, 2015 3:34 am
The car looks great.
As far as the photos I typically size mine to 800x600 for internet use, but here I have started to go with 600x450 or they won't fit in the frames as yours are doing.
Re: NYPD circa 1962
Postby GLMFAA1 on Mon Nov 02, 2015 9:05 am
Thanks for the tip, The old photobucket pics would reduce to fit, guess with progress you loose convenience
Re: NYPD circa 1962
Postby Gator52 on Wed Nov 11, 2015 12:17 pm
Well done!
Jonah
Gator52
Return to Law Enforcement
