Posting Pics 101
Test Out The Various Forum Features Here
Posting Pics 101
Postby Chris on Sat Jan 26, 2008 1:04 am
To post pictures, you have to host them somewhere else that allows hotlinking, in other words somewhere that lets you show the image here while they have it on their server.
The best place to host them is photobucket.com , it is free and they allow you to host a ton of pictures. They also make it real easy to put the images in your post. After you upload the pictures you will see this under your image thumbnail.
Just click inside the box on the bottom and the tag will be automatically copied. Then just switch over to your post here and paste it in the text box. Hit submit and your post will have the picture in it. Easy as can be. :D
Now if hosting any where other than Photobucket, just click on the Img button in the tool bar above the posting box. Something like this will appear Just copy and paste the link to the pic between the ][ , just make sure that it ends in a photo extension such as .jpg, .gif, .png not .html or .htm . If you still have any questions , just ask.
Stay Safe,
Chris
Chris
Scale Firehouse Chief
Re: Posting Pics 101
Postby smokeater81 on Sat Jan 26, 2008 12:18 pm
Hey Chris I can't post pics from my photobucket, It says images can only be 600x800 pix. my properties says they are 160x120? We use the img code, right?
smokeater81
Postby Chris on Sat Jan 26, 2008 2:13 pm
Should be yea. I'll look at the settings and see if something needs to be changed.
Stay Safe,
Chris
Chris
Postby Chris on Sat Jan 26, 2008 2:38 pm
Took off the pic restriction, see if it will work now.
Stay Safe,
Chris
Chris
Postby smokeater81 on Sat Jan 26, 2008 6:23 pm
It works now. Thanks Chris
smokeater81
Postby cargostar on Sat Jan 26, 2008 6:37 pm
Ok I get an invaild photobucket error.
Postby Chris on Sat Jan 26, 2008 7:02 pm
Don't know why. Should be just the same as it was before. Same tags and all.
Stay Safe,
Chris
Chris
Postby cargostar on Sat Jan 26, 2008 7:09 pm
Ok I figured it out!
Postby ChrisMooney on Sun Jan 27, 2008 8:18 pm
Hey Chris my photos are getting cut off from the right... when i copied and pasted from phtot bucket half the Photo got cut off.
Postby ChrisMooney on Sun Jan 27, 2008 8:32 pm
Chris I changed my board back to the Acid text and the photo shows up great... But on the Carbon board it cut it off. I dont know :| must be something with the other Board set up.. can you get it figured out. or maby have the board set so it resizes the photos automaticly... like on the model cars mag board.
Postby Tiny 26 on Sun Jan 27, 2008 11:50 pm
I changed back to Acid Text for my eyes. The other looked cool, but my peepers couldn't hang with it.
Sweet rollback Cargo!!
Nice van Chris. Is it the old IMC or a Jimmy Flintstone?
Tiny (Bionic Redneck) & Canadian Wannabe
"Everything Happens For A Reason"
tinythemodeler@yahoo.com
Tiny 26
SFH Abuse Collection Officer
Postby Chris on Mon Jan 28, 2008 1:07 am
Chris, I'm not sure why they are not resizing , I'll see if that is something needs to be turned on or if it is a mod that needs to be installed. If I turn on the feature though that sets a limit for pic size, anything bigger apparently won't even show up. One of the little things that I am still learning myself.
Stay Safe,
Chris
Chris
Postby ChrisMooney on Mon Jan 28, 2008 11:10 am
OK now i see the whole thing Maby its my computer monitor :(
Postby Fireband12 on Tue Jan 29, 2008 3:47 pm
Test, test.....
Fireband12
Postby ChrisMooney on Tue Jan 29, 2008 8:52 pm
Fireband.... What image host are you using??? I might have to switch from Photobucket...
Postby R H on Sat Feb 02, 2008 1:05 pm
Chris wrote:To post pictures, you have to host them somewhere else that allows hotlinking, in other words somewhere that lets you show the image here while they have it on their server.
Chris, this will really cut down on what I post. I am still on pokey dial-up, with molassas connection rates (and the phone co. doesn't give a hoot). With that said, I do not have time to load my pictures to another site to link them over here. Sorry. Now I am missing the old board. :( It's going to be a couple of months before I get any kind of high speed (only one available here is cable, and it's only 1.8M download). In the summer months, I usually stay at a place that has high-speed cable(thier slowest is 6M).
Postby spd officer on Sat Feb 02, 2008 2:26 pm
Chris,
I set up an album in photobucket, I followed your directions, but it won't let cut and paste the pictures. Any suggestions. Thanks Dave
P.S. The only good way to use a computer is with a 45 caliber in hand.
spd officer
Postby spd officer on Sat Feb 02, 2008 3:38 pm
Chris,
I figured out what I was doing wrong...I think I'm ready to fly the space shuttle know. Thanks Dave
spd officer
Postby struitte on Thu Feb 14, 2008 11:16 pm
like this !!!
struitte
Postby Chris on Thu Feb 14, 2008 11:21 pm
I have since figured out that the auto copy works if Java is enabled on your computer. If not, then you have to do it the manual way.
Rob, posting pics is the same way as it was on the old forum. Even the forum code used.
Stay Safe,
Chris
Chris
Postby R H on Sat Feb 16, 2008 1:03 am
Chris wrote:Rob, posting pics is the same way as it was on the old forum. Even the forum code used.
Chris, I get "The extension jpg is not allowed." when I try it.
Postby cargostar on Sun Feb 17, 2008 4:50 pm
I just tried it and get the same message as RH
Postby Chris on Sun Feb 17, 2008 7:25 pm
Does it do it every time or occasionally?
Stay Safe,
Chris
Chris
Postby R H on Mon Feb 18, 2008 11:28 pm
cargostar wrote:I just tried it and get the same message as RH
Cargostar, if you're trying to post direct from your hard drive, you can't anymore. The new board cannot support it.
Postby cargostar on Mon Feb 18, 2008 11:41 pm
Can you post to the old board, and then move it here?
Next
Return to Testing
