My only build for 2010
Post Your Work From The Past Year!
Postby chariots of fire on Fri Jan 14, 2011 10:49 pm
The only complete build for 2010 is the Brockway/Mack crash truck. The Ward LaFrance is on the back burner for now. Wasn't complete in 2010 anyway.
Re: My only build for 2010
Postby Modelmaker on Sat Jan 15, 2011 12:10 am
And what an AWESOME build it is too.....Gary
Postby flashing light nut on Sat Jan 15, 2011 12:09 pm
It may have been your only build, but you knocked it out of the park. I whish I could work up the curage to attempt something remotely close to your build.
flashing light nut
Postby chariots of fire on Sun Jan 16, 2011 8:36 pm
To FLN: It's not courage you need but the right information and a bit of experience in scratch building. Have you ever tried any scratch building even the basic stuff?
Postby flashing light nut on Sun Jan 16, 2011 11:36 pm
chariots of fire wrote:To FLN: It's not courage you need but the right information and a bit of experience in scratch building. Have you ever tried any scratch building even the basic stuff?
Yes, I do a good amount of scratch-building on a regular basis. However, up to now, I've been sticking to scratch-building details, and minor stuff, with the largest project so far being an HO (1/87) scale barn.
Probably the biggest problem for me is that I try to get to technical when I build anything (i.e. I have to restrain myself from adding details that will never be seen, or will be hard to see when the model is completed) One of my character flaws, I guess.
flashing light nut
Postby Robbo on Mon Jan 17, 2011 1:13 am
Well, if that is all you have accomplished in 2010, then it was certainly worth the effort. A great scratch build model to be sure.
Cheers from Robbo in Australia.
Postby chariots of fire on Mon Jan 17, 2011 10:06 pm
To be sure the larger the scale, the more detail has to be put into it to make it look right. But that shouldn't scare you from giving it a go. Got any particular projects you might like to try?
Postby chariots of fire on Mon Jan 17, 2011 10:07 pm
Robbo wrote:Well, if that is all you have accomplished in 2010, then it was certainly worth the effort. A great scratch build model to be sure.
Thanks, Robbo!
Postby flashing light nut on Tue Jan 18, 2011 6:21 pm
chariots of fire wrote: Got any particular projects you might like to try?
Particular scratch-building projects that I qould like to try? Hmm, right now, the largest (in scale) would have to be a bed of some sort for my 1/24 scale Monogram Ford F-250 kit ( what type of bed is yet to be determined).
I'll probably start on that project as soon as I get my workbench cleared off from a couple of other projects I've got going.
flashing light nut
Postby FDNYDad on Mon Apr 09, 2012 2:49 pm
Charlie, Charlie, Charlie! If you keep doing these sweet builds like this one, you're gonna make me switch to 1/24th - 1/25th scale! I know you're doing a LOT of scratch building but, there just seems to be a lot more stuff available for 1/24th - 1/25th as compared to my poor old 1/32nd scale! :roll: :lol:
Mike :mrgreen:
..."Rescue 2, bring your squeegee with you"...
FDNYDad
Postby chariots of fire on Fri May 11, 2012 3:49 pm
You're right, Mike. A lot more in 1/25 and 1/24 but there are a lot of possibilities with some of the 1/32 diecast rigs as well. Guess I'm going to have to post some pics that I have of Jim Clarkson's 1/32 scale fire apparatus. His are totally scratch built. He uses a lot of the old Aurora Fire Truck tires and wheels but everything else comes from plastic stock of one sort or another.
Return to 2010 Builds Review
