old ford tires
old ford tires
Postby bigdogb25 on Sun Feb 23, 2014 2:54 am
Anybody know if these tires are available anywhere? I think Ma's Resin has the rims but I can't find the tires anywhere.
Any help will be appreciated.....Thanks
bigdogb25
Re: old ford tires
Postby chariots of fire on Mon Feb 24, 2014 1:21 am
Wish I did, Bob. I would have used them on my '38 Ford rig. The 1/24 scale Yat Ming open cab Ford has the right rims but they need to be modified some. Maybe you can find one cheap on e-bay.
Re: old ford tires
Postby EdselDan on Mon Feb 24, 2014 4:53 pm
I can probably give you a good Pattern for them, But,
Unless you have build a Paper model, You will NOT be able top use it.
And NO I do Not mean a simple tab a in slot b type model. I mean a VERY Detailed,
HIGH parts count model.
Brands include Modelik, GPM, Orlik, Maly Modelarz, GP Grafica.
They do Military vehicles in 1/25 NOT 1/35 like plastic & resin manufactures.
Want Large? How about a 1/33 scale B-52 Bomber!! SIX Feet Wing span!!!
The tire is made up of SEVERAL parts, including SEPARATE Tread!!!!!
Re: old ford tires
Postby Aaronw on Fri Feb 28, 2014 7:28 pm
What size tire & rim? I think I might have something like that but need to check.
