Ground based monitors
Postby mdlbldrmatt135 on Fri Jan 23, 2015 2:52 pm
Guys,
If I do any, would you rather have them folded for storage or have the option of having them open???
Thanks!!!
Re: Ground based monitors
Postby hooknladderno1 on Fri Jan 23, 2015 10:36 pm
Matt,
Not sure what you mean by "ground based". As the old saying "A picture paints a thousand words", can you post a photo(s) of what you mean? Thanks!
Postby Aaronw on Sat Jan 24, 2015 3:38 am
Assume he means a portable monitor. Something like this maybe?
http://www.elkhartbrass.com/products/mo ... multimedia
Depending on the style, yes, I could see a use for one deployed. Some of these monitors have a detachable top / nozzle that can be used mounted to the engine as a deck gun, or with their folding base for ground use. Others are always used on their base and are basically just deployed on top of the engine for use as a deck gun.
Postby Aaronw on Sat Jan 24, 2015 3:48 am
One of these Blitzfire monitors would be cool too. I've seen them carried in the hosebed of an engine attached to a hose like a nozzle for quick deployment. Also seen them secured on small pumpers for use as a deckgun. I wouldn't think it would be that hard to do the legs separate so they could be positioned open or closed allowing options for mounting?
http://www.tft.com/innovations/360viewe ... /index.cfm
Postby hookandladderno1 on Sun Jan 25, 2015 1:21 am
Aaron,
I second the vote for the Blitzfire nozzle! My hometown has one on their 2000 ALF Eagle engine. I am working on replicating it(the truck).
Postby mdlbldrmatt135 on Sun Jan 25, 2015 6:48 am
Well,
It's close. http://www.elkhartbrass.com/products/monitors/r-a-m/multimedia This is going to be the first one.
Users browsing this forum: No registered users and 2 guests
